looking value matter
sna
Excel Ver: Excel 365
Post by sna »
Hi Dear,
I need your help how to make formula for looking up a value
I try index with search but no luck
thank in advance
norkaz
Excel Ver: 2013,365
Re: looking value matter
Post by norkaz »
B2
=LOOKUP(2,1/SEARCH(IFERROR(LEFT(A2,(SEARCH(" ",A2)-1)),A2),$C$2:$C$3),$D$2:$D$3)
Norkaz
sna
Post by sna »
Thank you ,it works
norkaz
Excel Ver: 2013,365
Post by norkaz »
sna wrote: Sat Dec 11, 2021 5:04 pm Thank you ,it works
On the other hand, if the main criteria is followed by column C,
B2
=LOOKUP(2,1/SEARCH(LEFT($C$2:$C$3,SEARCH(" ",$C$2:$C$3)-1),A2),$D$2:$D$3)
Norkaz
