Excel query 1
sna
Excel Ver: Excel 365
Excel query 1
Post by sna »
Hi all
I need your help to solve the query as in attach
I need dynamic array excel 365
Thanks
Re: Excel query 1
:D Try this formula from Copilot,
=LET(
  dates, SORT(A5:A29),
  sales, SORTBY(B5:B29, A5:A29),
  n, 6,
  groupCount, ROUNDUP(ROWS(dates)/n, 0),
  idx, SEQUENCE(groupCount),
  startIdx, (idx - 1) * n + 1,
  endIdx, IF(startIdx + n - 1 > ROWS(dates), ROWS(dates), startIdx + n - 1),
  dateLabels, BYROW(idx, LAMBDA(i, TEXT(INDEX(dates, INDEX(startIdx, i)), "dd-mmm-yy") & " to " & TEXT(INDEX(dates, INDEX(endIdx, i)), "dd-mmm-yy"))),
  weekNos, idx,
  groupSums, BYROW(idx, LAMBDA(i,
    LET(
      s, INDEX(startIdx, i),
      e, INDEX(endIdx, i),
      range, SEQUENCE(ROWS(sales)),
      mask, (range >= s) * (range <= e),
      SUMPRODUCT(sales, mask)
  HSTACK(dateLabels, weekNos, groupSums)
Explanation:
  1. dates – Sorts the order dates from the range A5:A29
  2. sales – Sorts the sales values to match the sorted dates
  3. n – Number of days per group (e.g., 6 days per group)
  4. groupCount – Calculates the total number of groups, rounded up
  5. idx – Sequence of group numbers (e.g., 1, 2, 3, …)
  6. startIdx – Starting row index for each group
  7. endIdx – Ending row index for each group (capped at the last row)
  8. dateLabels – Creates a label like "02-Nov-24 to 07-Nov-24" for each group
  9. weekNos – Week number (e.g., 1, 2, 3, …)
  10. groupSums – Calculates total sales for each group using SUMPRODUCT with a logical mask
  11. HSTACK(...) – Combines dateLabels, weekNos, and groupSums into the final output table
sna
Re: Excel query 1
Post by sna »
Thanks for such awesome
sna
Re: Excel query 1
Post by sna »
I try it but no luck
=LET(
Data, B4:C28,
C,CHOOSECOLS,
D, C(Data,1),
S, C(Data,2),
Start, MIN(D),
WkNum, ROUNDUP((D - Start + 1) / 7, 0),
Wk, UNIQUE(WkNum),
WkStart, Start + (Wk - 1) * 7,
WkEnd, MIN(MAX(D), WkStart + 6),
Results, HSTACK(
TEXT(WkStart, "dd-mmm-yy") & " to " & TEXT(WkEnd, "dd-mmm-yy"),
Wk,
SUMIFS(S, WkNum, Wk)
VSTACK({"Dates", "Week No", "Total Sales"}, Results)
Re: Excel query 1
:D If you want to display the header, try this,
=LET(
  n, 6,
  weekNos, idx,
    LET(
  VSTACK({"Dates","Week No","Total Sales"},HSTACK(dateLabels, weekNos, groupSums))
sna
Re: Excel query 1
Post by sna »
Thanks you
