akung
Posts: 159 Joined: Sun Mar 11, 2012 10:20 am
by akung » Mon Aug 04, 2014 10:44 am
คิดว่าน่าจะเป็น Do loop แต่ไม่รู้จะปรับอย่างไรดีครับ
Sub SortData()
Dim SortData As String
Sheets.Add
ActiveSheet.Name = "SortData"
Sheets("Data").Select
Range("A10:A17").Select
Selection.Copy
Sheets("SortData").Select
Range("A1").Select
ActiveSheet.Paste
Range("B10:B17").Select
Selection.Copy
Range("A9").Select
ActiveSheet.Paste
Range("C10:C17").Select
Selection.Copy
Range("A17").Select
ActiveSheet.Paste
Range("D10:D17").Select
Selection.Copy
Range("A25").Select
ActiveSheet.Paste
Range("E10:E17").Select
Selection.Copy
Range("A33").Select
ActiveSheet.Paste
Range("F10:F17").Select
Selection.Copy
Range("A41").Select
ActiveSheet.Paste
Range("G10:G17").Select
Selection.Copy
Range("A49").Select
ActiveSheet.Paste
Range("H10:H17").Select
Selection.Copy
Range("A57").Select
ActiveSheet.Paste
Range("I10:I17").Select
Selection.Copy
Range("A65").Select
ActiveSheet.Paste
Range("J10:J17").Select
Selection.Copy
Range("A73").Select
ActiveSheet.Paste
Columns("A:A").Select
Selection.Sort Key1:=Range("A1"), Order1:=xlAscending, Header:=xlGuess, _
OrderCustom:=1, MatchCase:=False, Orientation:=xlTopToBottom, _
DataOption1:=xlSortNormal
Range("A1:A8").Select
Selection.Copy
Range("A10").Select
ActiveSheet.Paste
Range("A9:A16").Select
Selection.Copy
Range("B10").Select
ActiveSheet.Paste
Range("A17:A24").Select
Selection.Copy
Range("C10").Select
ActiveSheet.Paste
Range("A25:A32").Select
Selection.Copy
Range("D10").Select
ActiveSheet.Paste
Range("A33:A40").Select
Selection.Copy
Range("E10").Select
ActiveSheet.Paste
Range("A41:A48").Select
Selection.Copy
Range("F10").Select
ActiveSheet.Paste
Range("A49:A56").Select
Selection.Copy
Range("G10").Select
ActiveSheet.Paste
Range("A57:A64").Select
Selection.Copy
Range("H10").Select
ActiveSheet.Paste
Range("A65:A72").Select
Selection.Copy
Range("I10").Select
ActiveSheet.Paste
Range("A73:A80").Select
Selection.Copy
Range("J10").Select
ActiveSheet.Pastee
niwat2811
Posts: 350 Joined: Thu Jan 06, 2011 12:51 pm
Excel Ver: 2016
by niwat2811 » Mon Aug 04, 2014 11:05 am
ลองแนบไฟล์ตัวอย่างมาด้วยครับ
akung
by akung » Mon Aug 04, 2014 12:45 pm
วิธีการคือ ต้องการเรียงข้อมูลใหม่ ในกรณีที่มีการเปลี่ยนแปลง จากที่ยกตัวอย่างถ้า ลบ Cells ที่เป็นตัวอักษรสีแดง ระบบจะต้อง เรียงกันใหม่ให้ถูกต้องครับ ขอบคุณครับ
niwat2811
Excel Ver: 2016
by niwat2811 » Mon Aug 04, 2014 2:58 pm
ลองแบบนี้ว่าได้ตามต้องการไหมครับ
Sub test()
Dim lr As Long, lc As Long
Dim r As Range
Sheets.Add
Sheets("Data").Range("A10:J17").Copy Sheets("SortData").Range("A1")
For i = 2 To 10 Step 1
Cells(1, i).Resize(8, 1).Copy Range("A" & Rows.Count).End(xlUp).Offset(1, 0)
Cells(1, i).Resize(8, 1).ClearContents
lr = Range("A" & Rows.Count).End(xlUp).Row
For Each r In Range("A1:A" & lr)
If r.Font.Color = 255 Then
r.ClearContents
Columns("A:A").SpecialCells(xlCellTypeBlanks).EntireRow.Delete
lc = Cells(1, Columns.Count).End(xlToLeft).Column + 1
For i = 9 To lr Step 8
Cells(i, 1).Resize(8, 1).Copy Cells(1, lc)
Range("A1:J8").Copy Sheets("Data").Range("A10")
Sheets("SortData").Delete
akung
by akung » Mon Aug 04, 2014 4:52 pm
ขอบคุณมากครับ แต่ที่ทดสอบมัน Error ตรงนี้ครับ รบกวนด้วยครับ
ไม่เป็นแล้วครับ ไม่ทราบว่าเหตุใดเหมือนกัน
